RUMORS - canon 3D
popoloni
Iscritto: 06 Lug 2004
MessaggioInviato: Gio 03 Ago, 2006 9:13 am    Oggetto: RUMORS - canon 3D Rispondi con citazione
Here is part of a leaked document that's come into my possession:
Introducing the revolutionary EOS 3D.
Built from the ground up to represent the new face of digital imaging the EOS 3D will represent a breakthrough in high performance yet affordable photography. Featuring an elegant yet supremely functional design it takes the best of Canon's previous designs and enhances the experience even further. A high performance AF system featuring 27pt of which 11 are x-type down to f/4 while and the centre point is cross-type to f/5.6 and allows AF down to f/11. The AI servo performance has been significantly improved too, exceeding that of the 1D Mk II.
Also Canon proudly brings ECF to the digital era and is greatly enhanced in performance over that found in the Elan 7NE.
However, the true revolution lies in the heart of the camera. Packing an amazing 13.3MP into an APS-H sized sensor the images are processed by a new DIGIC III engine. The next generation DIGIC III Image Processor builds on the legendary abilities of the digic II with double the processing power necessary to deliver unprecedented levels of resolution, speed and dynamic range. Despite the EOS 3D having smaller pixels than the EOS 5D, the DIGIC III provides even greater DR, more accurate colour rendition improved WB and lower noise. ISO 50 and 3200 are now part of the standard ISO settings and ISO 25 and 6400 are now included as an expanded option. Also it further reduces power consumption allowing class leading battery performance.
Thanks to DIGIC III the EOS 3D also boasts an impressive burst rate of 6fps for 18 shots in RAW and 40 in jpg.
In addition the body adds several sealing gaskets to the all magnesium shell allowing for operation in more extreme environments. A new evaluative algorithm allows more accurate metering in extreme lighting and can even correctly expose subjects like snow. Also a 2.4% spot meter allows for precise metering of any part of the scene. The viewfinder shows an impressive 98% of the scene both horizontally and vertically. Also for the first time Canon will be employing 2.75" OLED display screen, offering superior resolution, brightness and power consumption to LCD screens and having markedly better performance in bright daylight.
POPOlog
IN VENDITA: -
black_paint_2003
Iscritto: 06 Giu 2005
MessaggioInviato: Gio 03 Ago, 2006 9:14 am    Oggetto: Rispondi con citazione
non e' che potresti tradurre? Very Happy Very Happy Very Happy
La mia mira e' il vostro piacere!
popoloni
MessaggioInviato: Gio 03 Ago, 2006 9:16 am    Oggetto: Rispondi con citazione
POPOlog
IN VENDITA: -
popoloni
Ecco il piano di rilascio delle prossime CANON digitali:
http://www.dialogen.no/foto/EOS_cameras.pdf
 Dimensione:  34.31 KB
 Visualizzato:  File visto o scaricato 1012 volta(e)
POPOlog
IN VENDITA: -
Ultima modifica effettuata da popoloni il Gio 03 Ago, 2006 9:21 am, modificato 1 volta in totale
popoloni
MessaggioInviato: Gio 03 Ago, 2006 9:17 am    Oggetto: Rispondi con citazione
Ti basta come traduzione? Ovviamente è tutto opinabile visto che il piano non riporta la 3D LOL
PS: obiettivo arrivato Ok!
POPOlog
IN VENDITA: -
Ultima modifica effettuata da popoloni il Gio 03 Ago, 2006 9:22 am, modificato 1 volta in totale
Oban
Iscritto: 06 Mgg 2005
MessaggioInviato: Gio 03 Ago, 2006 9:22 am    Oggetto: Rispondi con citazione
E' una bufala! Perchè non è possibile che costruiscono una 40mm f/1.2 in diametro di 52 mm, sarebbe una fantascienza! Pensate che una 85mm f/1.2 misura 77 mm.
Mai più
AleZan
coordinatore
Iscritto: 16 Giu 2006
Ma è tutto vero...... Mandrillo
Qual'è la fonte del doc?
Comunque è bello anche sognare...... (ma è tutto molto verosimile, magari arriva davvero)
black_paint_2003
popoloni ha scritto:
Ti basta come traduzione. PS: obiettivo arrivato Ok!
Ok! sei contento?vero che e' nuovo?
Oban
MessaggioInviato: Gio 03 Ago, 2006 9:26 am    Oggetto: Rispondi con citazione
Manca 40d? LOL
Mai più
AleZan
coordinatore
In effetti se leggete i termini dell'accordo per la restituzione dei famosi 300 euro sulla 5D (acquisti in Italia esclusi).
L'articolo 2 contiene una strana formula che fa pensare ad una possibile sostituzione della 5D.
http://canoneos5dpromotion.onlinerebates.com/terms.aspx
Così sembra leggendo. Ed è strano. Tutti i prodotti si evolvono, ma perchè questa specificazione proprio sulla 5D ?
AleZan
coordinatore
MessaggioInviato: Gio 03 Ago, 2006 9:37 am    Oggetto: Rispondi con citazione
Però questa 3D nella Chart non la vedo.
popoloni
MessaggioInviato: Gio 03 Ago, 2006 9:39 am    Oggetto: Rispondi con citazione
E' quello che dicevo io... nel piano non c'è. Magari non è quella raffigurata sopra ma questa qui:
POPOlog
IN VENDITA: -
sottobosco
Iscritto: 19 Gen 2006
MessaggioInviato: Gio 03 Ago, 2006 9:45 am    Oggetto: Rispondi con citazione
ma perchè tutte le FF le fanno col BG incorporato, così diventano importabili....
mannaggia a chi le studia ste cose!!!!!!!!!! non possono fare una 3D nel corpo della 350d ?????????? Trattieniti Trattieniti Trattieniti Trattieniti Trattieniti Trattieniti Trattieniti Trattieniti Trattieniti
Attilio
kiruzzo
Iscritto: 29 Gen 2005
MessaggioInviato: Gio 03 Ago, 2006 9:52 am    Oggetto: Rispondi con citazione
La 5D non ha il grip Wink
popoloni
MessaggioInviato: Gio 03 Ago, 2006 9:57 am    Oggetto: Rispondi con citazione
E poi questa presunta 3D è APS-H: 1.3x, non FF!
POPOlog
IN VENDITA: -
YordanRhapsody
Iscritto: 11 Gen 2006
meraviglia, sogno, tripudio e fantascienza...
una 3d così sarebbe tutto quello che cerco, anche se non credo avrà un prezzo tanto accessibile...
sensore aps-h da 13.3Mpixel con digicIII, iso6400
uno spettacolo, tanto bella che... non credo uscirà per ora...
una macchina con queste caratteristiche, farebbe contenti tutti!!!
E d'un tratto capii che il pensare è per gli stupidi, mentre i cervelluti si affidano all'ispirazione.
sottobosco
MessaggioInviato: Gio 03 Ago, 2006 10:17 am    Oggetto: Rispondi con citazione
però è enorme lo stesso.... Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
sono abituato bene con la 350d... già la 20/30d mi sembrano grandicelle... Smile
Attilio
AleZan
coordinatore
MessaggioInviato: Gio 03 Ago, 2006 10:40 am    Oggetto: Re: RUMORS - canon 3D Rispondi con citazione
Mi sono guardato intorno. Questo doc (che sempre inizia così) è un po' dappertutto. Anche su un sito russo...
Nel forum di dpreview si stanno facendo un sacco di risate......
http://forums.dpreview.com/forums/read.asp?forum=1032&message=19439826
Very Happy
bdcpv
Iscritto: 02 Gen 2005
MessaggioInviato: Gio 03 Ago, 2006 10:48 am    Oggetto: Rispondi con citazione
non solo sul forum di dpreview stanno ridendo..... conosco personalmente persone " saccenti " in merito che rischiano coliche addominali per quanto ridono! LOL LOL LOL
comunque, come si dice, non c'e' fumo senza arrosto....... Mandrillo
presto vedremo.....
joe
bosozoku
Iscritto: 28 Set 2005
MessaggioInviato: Gio 03 Ago, 2006 3:15 pm    Oggetto: Rispondi con citazione
non è detto.. il valore di f è il rapporto tra la lunghezza focale e il foro da cui entra la luce.. quindi ad esempio in teoria 40 mm f1 = foro di 40 mm.. naturalmente la lente frontale eccede questa misura.. ma non so di quanto.. pensa a quanto è piccola la lente del 50 1,8 oppure fai il conto dell'85 1,2.
almeno... così mi pare.
la TIMELINE dei prodotti canon è una supposizione.. non una dichiarazione ufficiale.. non è detto che sia veritiera.. è una supposizione come la 3d.. (di cui circolano anche foto diverse in cui si legge eos 3 f con scritto sotto foveon..) comunque staremo a vedere.. almeno che uno non sappia qualcosa da fonti attendibili.. siamo tutti sullo stesso livello di supposizione.
io comunque ci spero... qualunque cosa esca mi rende contento per qualche giorno... quindi spero che ci sia una raffica di novità.. anche se sicuramente non finiranno nella mia borsa. Crying or Very sad
